Warning message
ACE 4710 same real servers, different ports.
Answered Question
Sep 8th, 2014
Hi! I have the following question based on a new site requirement. The following sites use the same back end servers. Names changed to protect the innocent and my finger fumbling with pretty names for my actual config.
I have two real servers being load balanced: 10.0.0.1 and 10.0.0.2
They have:
Site A URL= www.testsite.com:80
Site B URL= www.newstuff.com:81
I want Site B answering on port 81 for anything referencing the URL match for either port :80, and :81, then redirect to :81 anything that is on :80.
I want Site A answering on port 80 for anything not referencing the Site B URL.
How do I split the traffic coming in while also redirecting if only needed for the one site?
Also, one further question, how do I handle monitoring the ports up for each as validation for the VIP? If either port goes down is that going to take both of them offline?
Correct Answer by Fnu Kanwaljeet Singh about 2 years 11 months ago
Was thinking there:) Please add the below configuration to above and see if that is what you are looking for. Basically we are redirecting any request which will come on second URL with port 80 to 81.
class-map match-all Test_81_redirect
   4 match virtual-address 10.1.1.2 tcp eq www
rserver redirect REDIRECT
Webhost-redirection http://%h%p:81
Serverfarm redirect Redirect
rserver REDIRECT
inservice
policy-map type loadbalance http first-match http_81_redirect
Class Test_81_redirect
Serverfarm Redirect
policy-map multi-match Test
  loadbalance vip inservice
    loadbalance policy http_81_redirect
  class Test_80
    loadbalance vip icmp-reply active
   class Test_81
Kanwal
Note: Please mark answers if they are helpful.
Since they are two different URL's, they would be resolving to two different VIPs. You can create two serverfarms with same servers but listening on ports 81 and 80 and create a class-map for different IP's or even same IP, listening on port 81 and 80. Any client coming with port 80 as destination would be loadbalanced to serverfarm_80 and any client coming on port 81 as destination would be loadbalanced to serverfarm_81.
class-map match-all Test_80
  2 match virtual-address 10.1.1.1 tcp eq www
  3 match virtual-address 10.1.1.2 tcp eq 81
rserver r1
ip address 10.0.0.1
inservice
rserver r2
ip address 10.0.0.2
inservice
serverfarm_80
rserver r1 80
inservice
rserver r2 80
inservice
serverfarm_81
rserver r1 81
inservice
rserver r2 81
inservice
  class class-default
    serverfarm serverfarm_80
  class class-default
    serverfarm serverfarm_81
  class Test_80
   class Test_81
Let me know if you have any questions.
Kanwal
Overall Rating: 5 (2 ratings)
Correct Answer
Fnu Kanwaljeet Singh Mon, 09/08/2014 - 08:48
  • Cisco Employee,
rserver r1
ip address 10.0.0.1
inservice
rserver r2
ip address 10.0.0.2
inservice
serverfarm_80
rserver r1 80
inservice
rserver r2 80
inservice
serverfarm_81
rserver r1 81
inservice
rserver r2 81
inservice
  class class-default
  class class-default
  class Test_80
   class Test_81
Kanwal
kpruett Mon, 09/08/2014 - 08:56
I think I hosed up my description a bit. My apologies, Kanwal.
Those two servers are a load balanced pair. They answer for both URL's, but the destination port differs based on the URL. And anything for the Site B url on the wrong port :80, should get redirected to the right port :81.
I've done redirects before, but this one is more complicated as I have two different URLs being handled, and a different destination port based on the URL.
Correct Answer
Fnu Kanwaljeet Singh Mon, 09/08/2014 - 11:29
  • Cisco Employee,
rserver REDIRECT
inservice
Serverfarm Redirect
  class Test_80
   class Test_81
Kanwal
kpruett Mon, 09/15/2014 - 05:26
Kanwal,
Sorry for the late reply, I had to wait until our cutover window to try to apply this. For the most part, your configuration worked. In my rush to get things configured, I missed that you specified the port within the serverfarm definition. Without out that, it took some time for me to spot what I had missed.
Thank you again for the assistance and help, VERY much appreciated. I'm marking your answers complete now.
