Warning message
GUI for Cisco Router 3800 Series
Sep 9th, 2014
I am new to networking. I have a CISCO 3800 series router. I do have admin access, moreover I can configure it using CLI through Hyper terminal. I would like to ask if there is some GUI (maybe web based) that I can also use to check and perform configuration...Thanks
michael o'nan Tue, 09/09/2014 - 15:08
  • Silver, 250 points or more
You could use SDM to manage this router. It is worth noting that the GUI is very limited and learning the CLI will be very useful.
Richard Burts Tue, 09/09/2014 - 18:34
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
In addition to SDM you have an option on the router to enable http server and the secure server. If you enable one or both of these you should be able to manage and configure the router using a normal browser session.
Rick
