Warning message
NEXUS 56128P
Sep 10th, 2014
  • Bronze, 100 points or more
It is not directly clear from the documentation, but i assume all 48 standard onboard SFP+ ports support FEX connectivity and FCOE possibility ?
regards,
GN
InayathUlla Sharieff Wed, 09/10/2014 - 07:34
  • Cisco Employee,
Yes you are correct.
Cisco Nexus 56128P Switch: The Cisco Nexus 56128P is a 2RU switch (figure 3) that supports 2.56 Tbps of bandwidth across 48 fixed 1 Gigabit and 10 Gigabit Ethernet SFP+ ports, and four 40-Gbps QSFP+ ports (Figure 3). The Cisco Nexus 56128P offers two expansion slots to support 24 ports of 10 Gigabit Ethernet and FCoE or 8/4/2-Gbps Fibre Channel and two ports of 40 Gigabit Ethernet using QSFP optics.
The Cisco Nexus 56128P (figure 4) also offers two slots for a Generic Expansion Modules (GEM). The GEM for the Cisco Nexus 56128P provides 24 ports 10G Ethernet/FCoE or 2/4/8G Fibre Channel and 2 ports 40 Gigabit QSFP+ Ethernet/FCoE ports. The expansion module supports native 40 Gigabit Ethernet on the QSFP+ ports. The expansion module is supported on the Cisco Nexus 56128P chassis only and can be populated in either of the two expansion slots.
Inayath.
