BAT for Gateway Configuration
Sep 11th, 2014
Hi ,
I am trying to import gateway configuration (MGCP) via BAT
Previous post i reffered to was
https://supportforums.cisco.com/document/144461/how-migrate-h323mgcp-gat...
It was helpful to get me to upload.
Its not clear what extra commas i need to remove..
Upload was completed.
Job schedule was completed too.
But changes is not reflected. (i just changed the description of gateway)
In Job logs i get the below message: MGCP Slot java.lang.NullPointerException
Overall Rating: 5 (1 ratings)
Nadeem Ahmed Thu, 09/11/2014 - 05:32
  • Cisco Employee,
Can you check are there are several "Commas" after each of the lines; what you need to do remove all the additional commas by opening this using wordpad or notepad++ .
Br,
Nadeem
