CME Ios
zavira123
hi all
i use gns3 to build simulation for my CCNA Voice
my question is that should i insert CME Ios to Router?
or one of the Enterprise IOS that router has sufficient and support full voice ?
2 Accepted Solutions
Hi.
On GNS3 you can simulate 37XX router which can mount 12.4(25d) as latest release which has CME 7.0 built-in.
Adv enterprise contains that release of CME.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi.
Adv IP services, merges SP and Security services.
With SP Services you have Data services + Voice
So yes you can download it
Carlo
9 Replies 9
Hi.
Carlo
could u please put me link for download 37xx ios router that you said?
Hi.
Here you are
http://software.cisco.com/download/release.html?mdfid=273764423&flowid=7314&softwareid=280805680&release=12.4.25d&relind=AVAILABLE&rellifecycle=MD&reltype=latest
Carlo
can i download
c3725-advipservicesk9-mz.124-25b.bin
is it work or not?
Hi.
Carlo
thnks
but which one i should download there are lot of ios?
Select the IOS with filename :
c3745-adventerprisek9_ivs-mz.124-25d.bin
It contains all you need
Carlo
again thanks alot carlo
Glad to help and thank you for nice rating.
Cheers
Carlo
