Warning message
voice traffic- bandwidth
Answered Question
Sep 15th, 2014
Hi Experts..
Pls help me in setting up QoS for my company. I have MPLS circuit for my all company locations. Main locations has 60mb MPLS circuit and branch locations has 20mb each. I have CME in my main location to which VOIP phones are registered. Since past few days i have been observing bandwith choke of my main location, due to this calling through VOIP phones from main locations to hub locations are getting drop intermediately.
I am looking to prioritize voice traffic so that other traffic could not make impact on voip calls. I want to assign 10mb bandwith to voice traffic and rest bandwith for others traffic.
Pls help me good way to configure this.
Correct Answer by Joseph W. Doherty about 2 years 11 months ago
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I think it should.
Overall Rating: 5 (1 ratings)
Joseph W. Doherty Mon, 09/15/2014 - 05:58
Disclaimer
Posting
How QoS might be implemented depends on your equipment, topology and MPLS vendor's support of QoS.  Insufficient information to suggest a good way to configure.
Anukalp S Mon, 09/15/2014 - 06:34
 Hi Joseph.
I have terminated MPLS circuit on 2911 router on each locations . I have mesh topology.
Yes MPLS vendor does support QoS. Does this implementation require their involvement too?
Actually users in one of my branch location do uploading/download files on servers in main location.
This cause my mail location bandwidth choke and due to this voice call gets impacted.
Joseph W. Doherty Mon, 09/15/2014 - 09:49
Disclaimer
Posting
Well although you have a mesh, if ALL your traffic is flows hub-and-spoke, you could do QoS w/o MPLS QoS, but the latter does (greatly) simplify it.
With MPLS QoS, get classes for the VoIP bearer traffic,(optionally) VoIP signalling, and default.  Then apply interface QoS to map your VoIP ToS correctly (for MPLS) and have egress QoS define matching queues.
Anukalp S Tue, 09/16/2014 - 02:47
Thanks Joseph.. could you post config example, that would be much appreciated.
Joseph W. Doherty Tue, 09/16/2014 - 06:28
Disclaimer
Posting
policy-map sample
class voip-bearer
priority percent 33
class voip-signaling
bandwidth remaining 10 percent
class class-default
bandwidth remaining 90 percent
fair-queue
For above, you need to classify traffic and mark to agree with MPLS QoS support.  Percentages might also be changed to agree with MPLS QoS.
Apply above as an out policy on MPLS egress port.
Anukalp S Tue, 09/16/2014 - 07:02
Thanks Joseph, really helpful. I am a bit confuse about what i need to match under class voip-bearer & voip-signalling. Do i need to match using "match ip dscp ef" or something else.
Also pls let me know, do i need to involve ISP to configure QoS for me at their PE router. OR applying QoS  on CE egress interface is sufficient.
Joseph W. Doherty Tue, 09/16/2014 - 09:40
Disclaimer
Posting
Whether you can match on existing ToS markings depends on how your VoIP phones mark (often configurable) and what the network allows (i.e. CoS/ToS markings) up to your WAN router.
Yes, you should be involved with your MPLS vendor as you described you have a mesh.
Anukalp S Thu, 09/18/2014 - 07:16
Thanks Joseph..
I am rather looking o classify based on ACLs. I have all VOIP phone having 10.122.101.0/24 IPs. And seeing classification using ACLs and match this ACL under class-map.
access-list 110 permit ip 10.122.101.0 255.255.255.0 any
class-map voice
match access-group 110
What you suggest, should this work also.
Correct Answer
Joseph W. Doherty Thu, 09/18/2014 - 08:46
Disclaimer
Posting
I think it should.
