Expressway sup
Maheshwar Tayal
Level 4
Level 4
Cisco Expressway C and E : Are they validated with B200 M3 blades?
do we have to refer which blades are validated.
George Thomas
Level 10
Level 10
Check out this link:
http://docwiki.cisco.com/wiki/Unified_Communications_in_a_Virtualized_Environment
Of the blade you are referring is in the TRC, you should be set. If its not a TRC, follow the specs based guidelines and you should be set.
Please rate useful posts.
