Warning message
authorization config-commands - doubts
Sep 16th, 2014
Hello Everyone,
So, for AAA Authorization,
When I issue : aaa authorization commands 15 default local. -> It will authorize every command on the exec for lvl 15.
The command above will overlap the: aaa authorization config-commands. ?!
I should use : aaa authorization config-commands. Just when i'm trying to authorize configuration commands ?!
nspasov Tue, 09/16/2014 - 17:57
  • Cisco Employee,
  • Cisco Designated VIP,
    2017 AAA, Identity and NAC Security
No, the aaa authorization config-commands is a must for the aaa authorization commands 15 default local to work. If the config-commands is missing from your config then no authorization will happen for level 15 commands. Take a look at this post:
https://supportforums.cisco.com/discussion/11409121/command-confusion-aaa-authorization-config-commands
Thank you for rating helpful posts!
