Warning message
Run an EEM applet on the basis of Reload Reason
Answered Question
Sep 17th, 2014
I want to run an EEM after router reloads only if the reload was initiated by an EEM applet. I want this EEM to trigger after 10 mins of reload.
Correct Answer by Joe Clarke about 2 years 11 months ago
Then you could have an applet that runs a reload and configures this other applet if the reload reason is right.  You can use the example below as a template:
event manager environment q "
event manager applet reload
 event timer cron cron-entry "@reboot"
 action 001 cli command "enable"
 action 002 cli command "show ver | inc Last reload reason: Embedded Event Manager action"
 action 003 regexp "Embedded Event Manager action" $_cli_result
 action 004 if $_regexp_result eq 1
 action 005  cli command "config t"
 action 006 cli command "event manager applet do-stuff"
 action 007 cli command "event timer countdown time 600"
 action 008 cli command "action 1.0 cli command enable"
 action 009 cli command "action 2.0 cli command $q config t$q"
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 09/18/2014 - 08:51
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I don't recall, but does the reload reason (in show ver) actually state reloaded by EEM (or similar) if an EEM policy reloads the device?
kiqbal0941 Fri, 09/19/2014 - 10:04
Yes it does as shown below...
Correct Answer
Joe Clarke Fri, 09/19/2014 - 10:36
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Related Content
