Warning message
Unity Connection - Port Group Server Order
Sep 19th, 2014
In Unity Connections I’d like to change the server order for PhoneSystem port group so that the ports for Unity Server register to a CUCM node at a different site as the primary option.  Are there any other settings that need to be changed to make this update other than just changing the order in the port group -> Servers list will suffice.
Jaime Valencia Sat, 09/20/2014 - 16:24
  • Cisco Employee,
  • Hall of Fame,
    2011
On the CUCM side make sure the CUCM group matches that config as well
zubairmoh Mon, 09/22/2014 - 06:47
Ok. So .. Just change the AXL servers on the Unity side and reset the voice ports on CUCM ??
