Warning message
sg200-50 admin GUI stuck at loading 70%
Sep 19th, 2014
Has anyone had this issue? I access the GUI through web browser and enter my credentials successfully, but then it just gets stuck on loading at 70% and gets nowhere.
I tried two different computers, and IE and Chrome browsers. Running windows 7 64-bit machines, IE 10, Chrome 37.0.2062.120 m
Any suggestions? Telnet disabled by default it seems.
rockrobi Mon, 09/22/2014 - 11:26
Good Morning mkleinhaus,
What firmware are you running?
You could try to reset the switch, as long as you have backed up your configuration
somewhere. (Or if you don't care about losing the current settings on the switch)
If you are entering the credentials of a user account you created, try the default "admin"
user account. The login credentials are cisco as the username and cisco for the password.
Here is a link to the Quick Start guide regarding any more questions you may have:
http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbss/sf20x_sg20x/quick_start/guide/ML/78-19596-01.pdf
Please let me know if this helps, and if you have any other questions.
Rocket
