Warning message
Route Redistribution
Sep 19th, 2014
We are curently redistributiong routes between eigrp to bgp and bgp to eigrp in our routers, 1st router being primary and the 2nd router as backup with below configuration :
Primary Router
 Router eigrp x
 network 0.0.0.0
 network 0.0.0.0
passive-interface Loopback0
 redistribute bgp XXXX route-map bgp to eigrp
 redistribute static metric xx xx xx xx
router bgp xxxxx
 network 0.0.0.0 mask 0.0.0.0
bgp log-neighbor-changes
 redistribute static
 redistribute eigrp xx route-map eigrp to bgp
neighbor 0.0.0.0  update-source Loopback0
 neighbor 0.0.0.0 remote-as xx
 neighbor 0.0.0.0  default-originate
 neighbor 0.0.0.0  soft-reconfiguration inbound
 neighbor 0.0.0.0  distribute-list 10 in
neighbor 0.0.0.0  remote-as xxxxxx
 neighbor 0.0.0.0  route-map local pref in
Backup Router
 router eigrp xx
network 0.0.0.0
network 0.0.0.0
redistribute static metric xx xxx xx xx xxx
 redistribute bgp xxxxx route-map bgp to eigrp
 router bgp xxxxx
 no synchronization
 redistribute eigrp x route-map eigrp to bgp
 neighbor 0.0.0.0 route-map as-prepend out
My question is about performing redistribiution from eigrp into bgp and from bgp into eigrp on both routers and if this may create loss of info. down the road as well as a possible asymetric routing issue within our other locations , so i wonder if my point is valid.
Another question i have is about neighbor....... soft-reconfiguration inbound and since i have recently read about bgp v.4 that supports a feature called route refresh which provides the same function so i wonder if we can remove neighbor ..... soft-reconfiguration inbound from bgp configuration and if it would generate a negative or positive impact on bgp configuration.
Could anyone provide some feedback please?
Overall Rating: 4 (2 ratings)
Akash Agrawal Sat, 09/20/2014 - 00:43
  • Cisco Employee,
Will try to answer your queries
1. Any possibility of routing loop :
   I am not sure about topology but while redistributing from eigrp to bgp, set some community and on other router while redistributing bgp to eigrp, dont redistribute prefixes with that community marked on R1.
Similarly while redistributing bgp to eigrp, set tag an use same tag not to redistribute back to bgp.
2.  Route Refresh vs Soft Reconfiguration
Please go through below link, having excellent explanation of both feature.
http://ccieblog.co.uk/bgp/route-refresh-capability-vs-soft-reconfiguration
--pls dont forget to rate helpful posts--
Akash
eandrcisco007 Mon, 09/22/2014 - 07:18
Hi Akash,
Thank you vey much, you have answered my question about Route Refresh vs Soft Reconfiguration,
Would you please provide a bit more details about your comments about # 1, possibility of a loop please?
Akash Agrawal Mon, 09/22/2014 - 09:44
  • Cisco Employee,
Can you please elaborate your question on below lines
"My question is about performing redistribiution from eigrp into bgp and from bgp into eigrp on both routers and if this may create loss of info. down the road as well as a possible asymetric routing issue within our other locations , so i wonder if my point is valid."
I mentioned possibility of loop in scenario when on R1 you redistribute bgp routes to eigrp and on R2 redistribute same external eigrp routes back to bgp and advertising it back to same AS which advertised prefixes on R1. This may create routing loop. Please correct me if i am wrong.
eandrcisco007 Mon, 09/22/2014 - 12:09
Hi Akash,Now i got your point, at firest I was confused about your statemenet but i got it, you are correct, thank you.
I am going to look into it,
About Route Refresh vs Soft Reconfiguration and according to provided link and explanation, i assume route refresh  advertises its information as it expected but would that be enough to remove neighbor....... soft-reconfiguration inbound from the router bgp configuration without having any ipmact?
