Warning message
Cisco IOS have more than 1 Tacacs Key?
Sep 20th, 2014
Hello, I will be transitioning networks and currently my devices point to one tacacs server, but within a week I will be needing to point to a different server on a completely different network. The current network is running one key, and the network that I will be transitioning too runs a separate key. Can I plug in the new  tacacs server config with the new key with no issues/
tjmaurin Sat, 09/20/2014 - 16:46
Earlier this year I changed the tacacs configuration on a few thousand devices by replacing the tacacs configuration using CLI access and Cattools.  These are the commands I entered:
service password-encryption
no aaa new-model
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa authorization config-commands
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
no tacacs-server host X.X.X.X
tacacs-server host Y.Y.Y.Y
tacacs-server key NewKey123
line con 0
 login authentication default
line vty 0 4
line vty 5 15
As far as multiple tacacs servers, you can use tacacs groups.  Here is a doc on that: http://www.cisco.com/c/en/us/td/docs/ios/12_2/security/configuration/guide/fsecur_c/scftplus.html#wp1001230
pvanvuuren Mon, 09/22/2014 - 02:20
  • Bronze, 100 points or more
Hi TroyBrock
The short answer is Yes, you can add the new tacacs server config with no serious issues.
You cold also add the command: " tacacs-server directed-request"   to your config and this way you can control to which tacacs-server you want to authenticate to.
So, you config could look something like this:
tacacs-server host 10.1.5.49 key cisco123            <---- your current  server
tacacs-server host 10.4.1.17 key ACS5.5-2013     <---- your new server
-> notice they have different shared keys.
The router will use the first tacacs ip address that appears in the running config.
a quick debug confirms this:
*Mar  1 00:16:33.287: TPLUS: Queuing AAA Authentication request 5 for processing
*Mar  1 00:16:33.287: TPLUS: processing authentication start request id 5
*Mar  1 00:16:33.287: TPLUS: Authentication start packet created for 5()
*Mar  1 00:16:33.287: TPLUS: Using server 10.1.5.49
*Mar  1 00:16:33.295: TPLUS(00000005)/0: Connect Error No route to host
*Mar  1 00:16:33.299: TPLUS: Choosing next server 10.4.1.17
*Mar  1 00:16:33.299: TPLUS(00000005)/0: Connect Error No route to host
But in the case that you want to authenticate against the second tacacs server, you need to add a string to your login. Like this :   [email protected] This will only work if you have the " tacacs-server directed-request" in you your config.
 Authorization and accounting will also use this tacacs-server ip you specified by the above command.
Hope it helps.
cheers
Pierre
