Warning message
mixed route list
Sep 20th, 2014
i am now using 7.1.5 callmanager, and i found that i cannot create a route list/route group with combination of qsig and sip trunk...
just want to know is the later version of callmanager can cope with this issue?
or any other alternative i can achieve this?
thanks.
Chris Deren Sat, 09/20/2014 - 08:07
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
I doubt this has changed, but how is your QSIG GW defined in CUCM, is it MGCP? How about if you convert it to SIP or H.323? Remember QSIG is TDM protocol, the protocol between CUCM and GW where QSIG is connected to can be any voip protocol, though QSIG over SIP may not be an option in your release (don't recall).
Chris
clileikis Sat, 09/20/2014 - 12:14
  • Gold, 750 points or more
Hi there,
From the admin guide it applies to CUCM a 10 as well:
If the route group contains a gateway that uses the QSIG protocol, only gateways that use the QSIG protocol display in the list. If the route group contains a gateway that uses the non-QSIG protocol, gateways that use the controlled intercluster trunks, which are QSIG protocol, do not display in the list.
As Chris suggested I would try converting to SIP or H323.
Chris
Melany Nolan Sat, 09/20/2014 - 12:46
Yes, it is mgcp ...
Than means nothing can be done in the future??
Chris Deren Sun, 09/21/2014 - 10:18
  • Hall of Fame,
You can convert your MGCP to H323 or SIP, pretty simply solution if you ask me. Upgrade would not help  you with this issue.
Chris
