7821 Cisco Phone with SRST Issue
Monzer Allam
Hello good day
dears please support me
i have 7821 ip phone and its SIP phone and its not working with SRST  in branch location . and as ber Cisco Compatibility Information can support from SRST v 8.6 and i'm already upgrade my routers IOS to 15.0 to support SRST 8.6 adn its not working . do you have any idea
 http://www.cisco.com/c/en/us/support/unified-communications/unified-survivable-remote-site-telephony/products-device-support-tables-list.html
Phone 7821
Routers 2801  IOS 15.1
             1861   IOS 15.1
               880   IOS 15.3
Thanks & Best Regards,
15 Replies 15
Chris Deren
Please post your SIP SRST configuration so we can confirm proper config.
Chris
kindly find in the below the router configuration
call-manager-fallback
 max-conferences 2 gain -6
 transfer-system full-consult
 ip source-address X.X.X.X port 2000
 max-ephones 5
 max-dn 10
 keepalive 40
Thank You :)
This SCCP SRST config, you need sip SRST for 78xx phones.
chris
dear Chris,
could you please help me for the SIP configuration please
many thanks
Here you go:
voice register global
 system message SRST Active
 max-dn 200
 max-pool 10
voice register pool  1
 id network 10.x.x.0 mask 255.255.255.0
Chris
hello Chris
thanks a lot for your kind support.
but sorry its not working :(
any extra idea .
thanks & Best Regards,
the below for your info
RTR#show voice register pool all
 Pool Tag 1
Config:
  Network address is 10.106.52.1, Mask is 255.255.255.0
  Proxy Ip address is 0.0.0.0
  DTMF Relay is disabled
  kpml signal is enabled
  Lpcor Type is none
  Reason for unregistered state:
         No registration request since last reboot/unregister
  paging-dn: config 0 [multicast]  effective 0 [multicast]
Dialpeers created:
Statistics:
  Active registrations  : 0
  Total SIP phones registered: 0
  Total Registration Statistics
    Registration requests  : 0
    Registration success   : 0
    Registration failed    : 0
    unRegister requests    : 0
    unRegister success     : 0
    unRegister failed      : 0
    Attempts to register
           after last unregister : 0
    Last register request time   :
    Last unregister request time :
    Register success time        :
    Unregister success time      :
Do you have SRST reference properly configured in CUCM and assigned to the phones'  device pool?
Dear Chris,
yes SRST reference assigend to phone device pool as per attached pic.
Can you provide "debug ccsip all" when the phones are suppose to register. Did you define proper subnets of the phones under the voice register pool?
Chris
Dear Chris,
yes the subnet under the voice register poll is correct.
and i'm enabled the Debug CCSIP all
INT-RDS-RTR#show debug
  Persistent variable debugging is currently All
CCSIP SPI: SIP Call Statistics tracing is enabled       (filter is OFF)
CCSIP SPI: SIP Call Message tracing is enabled  (filter is OFF)
CCSIP SPI: SIP Call State Machine tracing is enabled    (filter is OFF)
CCSIP SPI: SIP Call Events tracing is enabled   (filter is OFF)
CCSIP SPI: SIP error debug tracing is enabled   (filter is OFF)
CCSIP SPI: SIP info debug tracing is enabled    (filter is OFF)
CCSIP SPI: SIP media debug tracing is enabled   (filter is OFF)
CCSIP SPI: SIP Call preauth tracing is enabled  (filter is OFF)
CCSIP SPI: SIP Call transport tracing is enabled        (filter is OFF)
CCSIP SPI: SIP DHCP tracing is enabled  (filter is OFF)
INT-RDS-RTR#
the below FYI
  Version 10.0
  Mode is srst
  Max-pool is 5
  Max-dn is 50
  Outbound-proxy is enabled and will use global configured value
  Security Policy: DEVICE-DEFAULT
  Forced Authorization Code Refer is enabled
  System message is SRST Active
  timeout interdigit 10
  network-locale[0] US    (This is the default network locale for this box)
  network-locale[1] US
  network-locale[2] US
  network-locale[3] US
  network-locale[4] US
  user-locale[0] US    (This is the default user locale for this box)
  user-locale[1] US
  user-locale[2] US
  user-locale[3] US
  user-locale[4] US
  MWI unsolicited notify is disabled
do you need show run for all voice configuration on the router ??
Thanks & Bet Regards,
There is nothing showing in the debug implying the phones do not even attempt to register, yes please provide full config,
Chris
Dear Chris
kindly find the attached full config for the router ز
Thank you for your interest to help me :]
Best Regards,
Try adding:
Voice service voip
 allow-connections sip to sip
 sip
   registrat server
In my case that was the solution!!
Thanks!!
