Warning message
asdm upgrade wizard hangs
Sep 22nd, 2014
This used to work fine, until recently, now it just hangs when I attempt to use it.  Doesn't matter which version ASDM, from 6.4 though 7.15.  I start it, put in my CCO credentials, then wait as it just sits there.
Vibhor Amrodia Sat, 10/04/2014 - 23:22
  • Cisco Employee,
I think this might be related to JAVA or ASDM incompatibility.
What version of JAVA are you running ? Have you tried to upgrade the ASDM to the latest version available on CCO and see if that works.
Thanks and Regards,
Vibhor Amrodia
tahequivoice Mon, 10/06/2014 - 05:45
The problem started after upgrading ASDM, I just dont remember which version it stopped working on, or I would revert.  I manage and maintain several dozen various ASA, with different versions of ASDM installed, and I don't remember when it stopped working, I used it all the time.
rizwanr74 Mon, 10/06/2014 - 13:39
  • Gold, 750 points or more
Hi tahequivoice,
Can you try open it via Fire-fox browser and you also need to enable java plun-in from your computer's control-panel as shown in the image.
Let me know, if this helps.
Rizwan Rafeek
