Warning message
Dual Line problem with Cisco IP phone 99XX on CUCM 9.1
Answered Question
Sep 22nd, 2014
Hi, guys,
I tried to configure a device profile for 9971 with two DN lines, and I assigned it to an end user
which I logged in with into a Cisco IP phone 9971, the problem is that once I logged in, I'm finding only
the first DN line, the second is missing.
Knowing that I had the same problem with the 9951 model, I got no problem with 89XX models.
Can you, guys, give me some help regarding this issue?
I really appreciate your help, guys.
Best regards.
Correct Answer by Carlo Poggiarelli about 2 years 11 months ago
Hi.
Try to create another Phone Button template dedicated for that UDP. Try also to add the same Phone button template to a physical phone 9971 and try to login there
Carlo
Overall Rating: 5 (1 ratings)
George Thomas Mon, 09/22/2014 - 11:08
  • Blue, 1500 points or more
Did you set the phone button template on the device profile, did you create the 2nd DN on the device profile?
Correct Answer
Carlo Poggiarelli Tue, 09/23/2014 - 03:08
  • Green, 3000 points or more
Hi.
Carlo
Chris Deren Tue, 09/23/2014 - 05:59
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
What is the UDP based on, is it also 9971 phone?
Keep in mind there is a concept of extension mobility equivalency:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/8_6_1/ccmf...
so, if UDP based on a model is different from what you are logging onto some features may not work including line appearances.
Chris
