Warning message
Aironet 1141 won't power on
Sep 22nd, 2014
I have a Aironet 1141n that I can't get to power on using poe, I know the poe is good because it works with others. Does anyone have any ideas to try or know what is a common failure in these? Also where can I order a new board for it. I'm guessing it's would be a quick fix as there are only the main board and the radio inside.
Scott Fella Mon, 09/22/2014 - 11:23
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
I don't think you will be able to "FIX" that yourself.  Your better off looking on ebay and picking up a new AP to be honest.
Scott
Salma Sulthana Mon, 09/22/2014 - 18:10
  • Cisco Employee,
If it's dead on arrival, better replace the AP from your partner or with Cisco if it's covered under warranty or contract. if this was working fine and if it has gone down now, then it's better to check for your warranty and get it replaced from wherever you got it.
Salma
