Warning message
Which Cisco Prime version/suite will be able to create historical interface utilization graphs?
Sep 23rd, 2014
I would like to know which Cisco Prime SW suite can generate reports for interface utilization for a selected time range.
I want something very similar and simple like solarwinds or even MRTG.
I can get the utilization graphs per interface on PI, but that is not exportable nor save-able...
There is no report for interface utilization that includes the graph...
Please advise...
Ciao
Vinod Arya Tue, 09/23/2014 - 10:58
  • Cisco Employee,
I can check it on PI 2.x where Interface Rx and Tx utilization is available per interface basis on graph as per either octet or Percent basis:
This is under Operate > Monitoring Dashboards > Detail Dashboards > Interface. As it is a dashlet, unfortunately you can't export it.
I am not aware of other places, may be other community members can share from their experience.
-Thanks
Vinod
