Warning message
config RAID on MCS 7825 i5
Sep 23rd, 2014
Hello
I add a new HDD to my server ( MCS 7825 i5) that already bought with one HDD. now the server has 2 HDD.
My Problem is when I try to configure RAID 1 on my server it seem like the the controller not install.
so I need to make sure if the controller is installed otherwise Is there are any procedure to configure RAID on my server.
thank you for your relpys
Best Regards
youssef.erraki Tue, 09/23/2014 - 09:06
thank you for your reply it seem that not existe in the server I see with system ingeniere and he confirmed me that the card not existe in the server
thank you again for your reply
