Warning message
Console locked - Password check with invalid encryption type
Sep 23rd, 2014
HI,
So it appers that my console access is locked.  Worst thing is that my ssh vty is not setup properly so I can't access the switch.
What I don't understand I did not change any configuration under console 0 but only under vty.
Basically password for username was changed from password 7 to 5 and the following commands were performed:
username ciscoAdmin privilege 15 secret  <password>
Original settings:
line vty 0 4
password 7 <password>
logging synchronous
login
transport input ssh
Removed
No password 7 <password>
And added
login local
Console config:
line con 0
logging synchronous
login authentication CONSOLE
aaa authentication login CONSOLE line
Note this was done only under vty and not console.  I don't understand how this change would mess with console settings.
Now when accessing via console following commands pops up: Password check with invalid encryption type
I'm afraid I will need to reboot the switch since i didn't save the settings so it would go back to original.
Any advice would be greatly appreciated.
Thanks in advance.
