Warning message
End of Call
Answered Question
Sep 23rd, 2014
This is a real basic script I set up to prove the concept of sending data via HTTP Post for an after call survey.
It works fine but I am hung up trying to get the HTTP Post to go after the call is complete. The script as you see it send the data upon connection to the agent.
Any help is appreciated.
Dan
Correct Answer by Christian Drefke about 2 years 10 months ago
Hello Dan,
this won't work in just one script cause the script just continues after the call got connected. This is a normal behaviour since the call got handled and there is no need to keep the session up and running.
A solution might be to run a workflow action from your CAD after the call got disconnected, including the variables needed. The target could be a HTTP trigger that leads to a 2nd script that again does what you want. Or you open your HTTP trigger directly from the CAD action.
Christian
Overall Rating: 5 (1 ratings)
Gergely Szabo Wed, 09/24/2014 - 01:54
  • Green, 3000 points or more
  • Community Spotlight Award,
    Member's Choice, December 2015
Create URL Document does not issue a HTTP request, it only creates a reference. You need to use another step doing something with that reference. Cache Document would do.
Also, if I were you, I would probably set "No" to the "Connect" field at the "Select Resource" step, and after the "Selected" label I would insert all the HTTP related stuff and then use the Connect step to actually connect the call.
G.
dannoofWI Wed, 09/24/2014 - 05:37
Hi Gergely,
Thank you for the reply.
Actually the "Set PResult" line after the Create URL Document sends the HTTP Post. What I am hung up on is triggering the HTTP request after the call is finished. Right now the HTTP request is sent when the call is connected. I don't think moving the HTTP stuff before the connect step would fix that.
Dan
Gergely Szabo Wed, 09/24/2014 - 06:24
Hi, let me test something in my lab.
In the meantime, can you please tell me your UCCX's version. Thanks.
G.
Gergely Szabo Thu, 09/25/2014 - 05:08
I tried it, no success :-(
G.
dannoofWI Thu, 09/25/2014 - 07:38
Thank you for trying.
Perhaps someone will have an idea.
Dan
Correct Answer
Christian Drefke Thu, 09/25/2014 - 09:02
Hello Dan,
Christian
dannoofWI Thu, 11/13/2014 - 06:25
I set this up as a Voice Contact Work Flow and for the most part it works great.
Question is - contact center does not want the HTTP Post to trigger if the agent transfers the call. Since the call is already answered I believe the UCCX script is done. Is there a way to stop this trigger if the call is tranferred?
