Warning message
3650 MC integration with ISE
Answered Question
Sep 23rd, 2014
I was just wondering if the catalyst 3650 mobility controller could integrate with ISE in the same way that a WLC does.
But on another note, what is the main difference between the 3650 and a WLC as far as features go?
Cheers,
Waqas
Correct Answer by Rasika Nayanajith about 2 years 10 months ago
Hi Waqas,
This post will explain how to configure 3850/3650 for a 802.1X WLAN with ISE integration.
http://mrncciew.com/2013/12/06/wlan-config-with-3850-part-2/
3650/3850 (or any converged access platform) only support local mode AP deployments. So if your requirement is mixed mode AP deployment, then you need to think about it again.
Rasika
**** Pls rate all useful responses ****
Correct Answer by Saurav Lodh about 2 years 10 months ago
It will support
Overall Rating: 5 (2 ratings)
Correct Answer
Saurav Lodh Tue, 09/23/2014 - 15:54
  • Gold, 750 points or more
It will support
Correct Answer
Rasika Nayanajith Tue, 09/23/2014 - 16:56
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
Hi Waqas,
Rasika
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
