Warning message
Cisco Catalyst 2950 unable to get to web interface
Sep 23rd, 2014
Hello I have a Cisco catalyst 2950 Switch. I have reset the switch back to factory defaults and have entered the quick config mode (hold mode button for a few seconds till all the lights above go green). I have plugged in a ethernet cable into ethernet port 1 on the switch and can telnet into the device. I have also done the following
config t
ip http server
end
now it's supposed to bring up the web interface, but it's not giving me nothing. my IP configuration gives me an IP address but no Default gateway or DNS. I have tried to set manually and try to open the browser but still no go.
any suggestions on how I can get to the UI ?
Reza Sharifi Tue, 09/23/2014 - 16:58
  • Cisco Designated VIP,
    2017 LAN
Try adding "ip http server-secure"
and use https to login.
Smacneill1 Tue, 09/23/2014 - 17:11
I tried to enter the command and it it doesn't appear to like the - between the server and secure
thomas0020 Sat, 11/29/2014 - 10:23
@smacneill1
Do not use neither the assistant nor the menu: "smartports" on the website of your switch.
it will, for sure, destroy any of the configuration-parameters you entered before, it is just a way not to go all the way to your switch to see which LEDs are blinking.
Cisco Network Assistant, which will be represented to you as THE (only) way of easy configuring of your network hardware is even more aggressive, it will setup your hardware in a state you ´ve never wanted it to be.
The Cisco Hardware you are trying to configure is not meant to be configured in a way like ZYXEL or Netgear are.
You ´ll have to know about Ciscos own iOS and the connected CLI, no other way, believe me and sorry for that :(
maybe you want to enter the config t and to give an ip address to your vlan 1? a gateway would be great, too?
btw: sorry for my bad english
Smacneill1 Thu, 09/25/2014 - 13:36
I did a bit of looking around, and the router is in quick config mode. Also I am unsure if the web browser is even installed on the device. I type the show ip http command but it says that everything after IP is incorrect.
Anyone know if I can install the browser on there, or if it's even available in quick config mode ?
Related Content
