Is correct my telephony ordering setup?
waltermunguia
The goal is to implement one Telephony server for only 30 Cisco IP phones and try to use already deployed Analog telephony network by using four (04) Cisco VG224.
So I need to be sure that licenses are correct and no extra items are needed.
My Setup:
BE6K-ST-BDL-K9=
Cisco BE6000 Medium Density Server, Export Restricted SW
R-CBE6K-K9
Cisco Business Edition 6000-Electronic SW Delivery-Top Level
CISCO2901-V/K9
Cisco 2901 Voice Bundle, PVDM3-16, UC License PAK, FL-CUBE10
CP-7841-K9=
Cisco UC Phone 7841 (27 devices)
CP-7962G=
Cisco UC Phone 7962, spare (3 devices)
VG224-MP
VG224 for MultiPack (4 devices)
Regarding License I HAVE:
BE6K-UCL-ENH
Cisco Business Edition 6000 - Ehanced User Connect License (Quantity=05)
Beacuse Server binble includes: BE6K-START-UCL25 (BE 6000 - UCL Starter Bundle with 25 Enh and 25 VM Licenses )
VG224 (a total of 96 lines have to be licensed also?
rosaho
Level 3
Level 3
This discussion has been reposted from Additional Communities to the Business Edition 6000 community.
Andrew Hickman
Hi Walter,
For the VG224, the answer to your question is "it depends".
If you configure the device as an MGCP controlled gateway, then no additional licenses are required.
If you configure the device using SCCP, then you require one Essential license per activated VG224 port.
Hope that helps.
Andy
