Warning message
Download WLC 2504 Config and Upload to a WLC 5508
Answered Question
Sep 25th, 2014
Hi Community.
Is there a way to Download WLC 2504 Config and Upload it to a WLC 5508. As I know this is not possible but, is it possible to import a part of the config to a WLC 5508 controller. The config of the customer isn't complicated but he has a bunch of AP's with configured AP Names and Locations.
It would be good to export the AP's and import it to the WLC 5508.
Is there a solution for that ?
best Regards Patrick
Correct Answer by Rasika Nayanajith about 2 years 10 months ago
Hi Patrick,
AP Name & Locations won't be in a WLC config back up (rather remain in AP itself). So if you move APs to 5508 (from 2504), name & location  information of those AP will be there.
If you want to upload a part of configuration, you can simply take a back up of WLC configuration & apply required lines via CLI.
Rasika
**** Pls rate all useful responses ****
Overall Rating: 5 (1 ratings)
Correct Answer
Rasika Nayanajith Thu, 09/25/2014 - 04:28
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
Hi Patrick,
Rasika
gohussai Thu, 04/16/2015 - 12:17
  • Cisco Employee,
Yes it is possible if WCS is configure but it is recommended you do the manual process.
Further more as mention earlier AP Name & Locations will stick there.
For manual process like:
#copy running-config flash:backup-config
# transfer download datatype ?
And then on other WLC.
# transfer upload datatype ?  [it should be config]
Trending Topics - Security & Network
