Warning message
DX650 cannot call extensions from call history
Sep 26th, 2014
I have a problem with DX650 phone (Load ID: sipdx650.10-1-2-41) when trying to call an internal Extension from Call History. The problem is that the phone put the prefix 9 in front and the CM cannot dial the extension. I don't have any problem with National or International numbers.
Manish Gogna Fri, 09/26/2014 - 05:02
  • Cisco Employee,
Can you check if you have setup any rules to prefix 9 for outbound calls from DX650, the same may be getting applied to internal calls due to an overlap with the ones configured for national numbers.
Manish
Michalis Michael Fri, 09/26/2014 - 05:07
Thanks Manish for your answer. The problem was solved.
There was an Application Dial Rule with 4 digits in CM. I removed it and now it will be able to call extensions from call log.
I didn't know that DX650 reads the Application Dial Rules from CM...
Manish Gogna Fri, 09/26/2014 - 05:09
  • Cisco Employee,
That's good to know. The earlier firmware of DX650 did not have the ability to invoke dial rules but it was fixed recently.
Manish
