Warning message
Cisco Router 891-K9 Ipsec Site-to-site VPN configuration Issue?
Sep 26th, 2014
i have two 891-k9 Router and i want to configure Ipsec Site-to-Site VPN
When i type command #crypto ?   it will not give me option of isakmp
Please find below Show Version & Show Lic output of the router.
Router#
*Sep 25 13:01:12.719: %SYS-5-CONFIG_I: Configured from console by console
Router#sh ver
Cisco IOS Software, C890 Software (C890-UNIVERSALK9_NPE-M), Version 15.2(4)M6, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Wed 19-Mar-14 22:06 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB3, RELEASE SOFTWARE (fc1)
Router uptime is 3 minutes
System returned to ROM by reload at 12:57:38 UTC Thu Sep 25 2014
System image file is "flash:c890-universalk9_npe-mz.152-4.M6.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
 --More--        to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 891 (MPC8300) processor (revision 1.0) with 498688K/25600K bytes of memory.
Processor board ID XXXXXXXX
9 FastEthernet interfaces
1 Gigabit Ethernet interface
1 Serial interface
1 terminal line
256K bytes of non-volatile configuration memory.
254976K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
 --More--
Device#  PID SN
*0    CISCO891-K9                XXXXXXXX
License Information for 'c890'
    License Level: advipservices_npe   Type: Permanent
    Next reboot license Level: advipservices_npe
Router#   sh lic
Index 1 Feature: advipservices_npe
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Count: Non-Counted
License Priority: Medium
Index 2 Feature: WAAS_Express
Period left: Not Activated
Period Used: 0  minute  0  second
License Type: EvalRightToUse
License State: Not in Use, EULA not accepted
License Priority: None
Index 3 Feature: ios-ips-update
vishal vyas Fri, 09/26/2014 - 08:16
To configure VPN you need to have securityk9 licence, which I dont see here. If you have that licence then you need to enable the licence. You might need to change your IOS version to (advanceipserv) version.
Richard Burts Fri, 09/26/2014 - 08:57
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
It is not an issue with IOS version. It is an issue with license. The license information indicates "advipservices_npe". The issue is npe which is not payload encryption and does not support crypto IPSec. The original poster needs a license upgrade to be able to use these routers for site to site VPN.
Rick
