Warning message
Aman Soi Tue, 09/30/2014 - 10:15
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 IP Telephony
You can simply run License Count Utility [downloadable from Cisco] .Run it on PC from where Publisher is reachable.
Once done, u will get an excel file consisting of used /unused DLUs , MAC address /IP address of Publsiger and count for CUWL /UCL users.
After u migrate to CUCM 10, share this file along with txt file generated from PLM to licensing@cisco.com to get the permanent license for users.
regds,
aman
ivansalazar Tue, 09/30/2014 - 12:37
Hi Aman,
Thanks fot the answer. But I'm looking forward to check wich part numbers are correct in order to have a migration without UCSS and Smartnet. So I wonderign if I should order:
R-CUWL-STD-K9
MIGE-UCM-UWL-STD
OR
R-UCL-UCM-MIG-K9
MIG-CUCM-USR-A
R-CUWL-STD-K9
MIGE-UCM-UWL-STD
Ivan
Aman Soi Wed, 10/01/2014 - 03:54
    2017 IP Telephony
Hi Ivan,
You need to place order for below since the users are different.Run the LCU to get the correct count.
R-UCL-UCM-MIG-K9
MIG-CUCM-USR-A
R-CUWL-STD-K9
MIGE-UCM-UWL-STD
regds,
aman
