Add AP License to AIR-CT5760 WLC
Sep 30th, 2014
Hi Everyone,
Our question here is how to upload AP license, file .lic into AIR-CT5760 WLC?
The interface inside too much different with WLC 4400 and WLC 5500 series.
I have experienced before to add AP license for WLC 5508 series. And I thought the procedure is same.
I hope you guy can help me and if possible give me the procedures how to upload that file .lic.
Thank you very much for your help.
-syukri-
Overall Rating: 4 (1 ratings)
Rasika Nayanajith Tue, 09/30/2014 - 20:40
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
This should help you to get start with your 5760
http://mrncciew.com/2013/12/12/getting-started-with-5760/
These models (5760/3850/3650) all using "right-to-use license" & it is different to AireOS (5508.2504,etc)
http://www.cisco.com/c/en/us/products/collateral/wireless/5700-series-wireless-lan-controllers/qa_c67-726397.html
So something like is required to activate AP count license on your 5760.
license right-to-use activate apcount <count> slot 1 acceptEULA
This post also may be useful (as it describe IOS upgrade, licence adding, etc) Do not worry about model 3850, those config same on 5760 as well.
http://mrncciew.com/2013/09/29/getting-started-with-3850/
Rasika
**** Pls rate all useful responses ****
syukri7179 Wed, 10/01/2014 - 21:14
Hi Rasika,
Thank you for your info. Very useful to me.
Below is done for our AIR-CT5760.
I got the result after do the 'command'.
Why the <COUNT> part is 0 even I already put 100 in the command.
Is it correct?
So what is next?
To adding the license .lic use command copy tftp:xxx.lic flash:   right?
Can I upload the file .lic into controller using GUI? If possible please guide me.
Sorry broken english. HiHiHiHi.....
Rasika Nayanajith Wed, 10/01/2014 - 22:15
    2017 Wireless
What is the IOS-XE version on your 5760 ?
If you are running latest (3.6E) then you can activate it in using GUI (Administration -> Software Activation -> Licences) as well.
Pls provide "show version" & "show license right-to-use summary" output.
Rasika
