Warning message
Unity Connection and local admin
Oct 1st, 2014
  • Silver, 250 points or more
I need to add a user to administrate the CUC system but with restricted access. I`m looking to add them as a user without a mail box however the CUC is synch`ed with LDAP. Does above relies on the user needing to be in LDAP first or can I just add them in CUC only, as I need to add an Alias will this only be significant in CUC ?
Also I need to change the GUI admin password but keep getting  code = 4 "invalid length" even though it is the same number of letters in the existing password
thanks
Aman Soi Wed, 10/01/2014 - 07:36
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 IP Telephony
for the second query , try using totally different password from the existng one.
utils cuc reset passsword OSuser credentials.You can refer the link
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/9x/user_ma...
Changing the LDAP Integration Status of an Individual Connection User
regds,
aman
