Warning message
DHCP Snooping database - The current agent is active
Oct 1st, 2014
Hello, I need to change an database URL. But switch can't end active agent.
After release of command I get an message, and nothing happend. After release "no" the result is the same.
I had tried no ip dhcp snooping and also use a timers to expire, but I think switch have got a software error.
Version 12.2(33)SXH6, RELEASE SOFTWARE (fc1)
switch#ip dhcp snooping database scp://user:[email protected]/tftpboot/snooping/switch
%Cannot change URL.  The current agent is active.
Sunil Bhadauria Wed, 10/01/2014 - 14:13
  • Cisco Employee,
Hello Philip ,
i have seen similar cases and a reboot should help clear the issue .
Sunil Bhadauria
! Kindly rate all helpful posts and accordingly mark correct to help forum !
Filip POHRONSKY Fri, 10/03/2014 - 05:24
Hi Sunil, that was the last idea I had got.
The one before the last was write on this support forum.
So I tried everythink but  reboot. Which is little bit strange solution.
Thank you.
Related Content
