Can I connect two CT5760 (Wireless) fow HA just with one stack cable?
Answered Question
Oct 1st, 2014
Hi guys,
I have two CT5760 so but just one of them came with a stack cable. Can I do a HA connection with just one STK cable, I friend of mine intentend to do this ask yesteday and he sent me this output:
WLC#show switch stack-ports summary
Sw#/Port#  Port Status  Neighbor  Cable Length   Link OK   Link Active   Sync OK   #Changes to LinkOK  In Loopback
1/1        DOWN         NONE      Unknown        Yes       No            Yes       0                   No
1/2        DOWN         NONE      Unknown        Yes       No            Yes       0                   No
Correct Answer by Stephen Rodriguez about 2 years 10 months ago
you should be able to do it with just one cable, per the 5760 HA guide, two is recommended for a 'full ring':
http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/5700/...
HTH,
Steve
Overall Rating: 5 (1 ratings)
Jorge Cantillo Wed, 10/01/2014 - 08:55
Thanks Steve. I will try it today. I've seen both controllers are using Version 03.02.03.SE RELEASE SOFTWARE (fc2) and the Part number is:
NAME: "Switch 1", DESCR: "AIR-CT5760-6"
PID: AIR-CT5760        , VID: V03
Do you know what mean the last 6 of the description?
Thnks
Jorge
Jorge Cantillo Thu, 10/02/2014 - 07:41
Thanks Steve, I upgraded to IOS XE 03.03.04SE in order to support HA.
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
