Warning message
MM_WAIT_MSG6 & Header invalid, missing SA payload! (next payload = 4)
Oct 1st, 2014
I came across this today while migrating a L2L / site to site tunnel from our ASA to a PaloAlto firewall (formerly Cisco ios device)
From my side I would see :
17  IKE Peer: x.x.x.x
    Type    : L2L             Role    : initiator
    Rekey   : no              State   :  MM_WAIT_MSG6
Solution 1: This typically means the PSKs don't match, after we fixed that we saw this. Some Mfgrs do not process special characters the same.
Debugging shows:
%ASA-vpn-4-713903: IP = x.x.x.x, Header invalid, missing SA payload! (next payload = 4)
or
Oct 01 10:33:43 [IKEv1]: IP =x.x.x.x Header invalid, missing SA payload! (next payload = 4)
The other side was able to see this:
"IKE phase-1 negotiation failed. When pre-shared key is used, peer-ID must be type IP address. Received type FQDN."
These errors mean that the ASA is sending it's DNS name entry for some reason.
Solution 2:  Configure "isakmp identity address"
ASA(config)# isakmp identity ?
configure mode commands/options:
  address      Use the IP address of the interface for the identity
  auto            Identity automatically determined by the connection type: IP address for preshared key and Cert DN for Cert based connections
                     hostname   Use the hostname of the router for the identity
  key-id         Use the specified key-id for the identity
Citation: http://www.cisco.com/c/en/us/td/docs/security/asa/asa84/configuration/gu...
D
  Determining an ID Method for IKEv1 and IKEv2 ISAKMP Peers
During ISAKMP Phase I negotiations, either IKEv1 or IKEv2, the peers must identify themselves to each other. You can choose the identification method from the following options:
Address
Uses the IP addresses of the hosts exchanging ISAKMP identity information.
Automatic
Determines ISAKMP negotiation by connection type:
http://www.cisco.com/c/dam/en/us/td/i/templates/blank.gifIP address for preshared key.
http://www.cisco.com/c/dam/en/us/td/i/templates/blank.gifCert Distinguished Name for certificate authentication.
Hostname
Uses the fully qualified domain name of the hosts exchanging ISAKMP identity information (default). This name comprises the hostname and the domain name.
Key ID
Uses the string the remote peer uses to look up the preshared key.
The ASA uses the Phase I ID to send to the peer. This is true for all VPN scenarios except LAN-to-LAN IKEv1 connections in main mode that authenticate with preshared keys.
The default setting is auto.
To change the peer identification method, enter the following command:
crypto isakmp identity {address | hostname | key-id id-string | auto}
For example, the following command sets the peer identification method to hostname:
hostname(config)# crypto isakmp identity hostname
JP Miranda Z Thu, 09/08/2016 - 13:49
  • Cisco Employee,
Also from the ASA perspective, make sure you are using the IP of the peer on the tunnel-group configuration.
Hope this info helps!!
Rate if helps you!!
-JP-
