copy startup-config tftp + %Error opening tftp://192.168.0.12/router-confg (Socket error)
JackDanial23
Please advise me on the below error;; I am using tftpd for tft
Router#copy startup-config tftp
Address or name of remote host []? 192.168.0.12
Destination filename [router-confg]?
Reza Sharifi
Try this and than test again.
http://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/49683-serviceconfig-error-msgs.html
Thanks Sharifi, Did that... but the error is still the ame
This was the right answer.. Solved
https://learningnetwork.cisco.com/thread/56041
im surprised you can ping without attaching a crossover cable.
because if your only using your console port to connect your pc...then you dont have ip connectivity
i think the cable your using to connect your pc to your router fa port is a straight through ethernet cable....
you see it attaches to a switch port in the back of your home router(not cisco router)
not a router port.
so you need a different cable depending on how you want to connect to your router.
you can check to see if it is a crossover cable
just peer down the end of the cable you can see the colours...
if they are in the same order on each end...then it is a straight through cable
if they have a different order...then it is a crossover cable
if your connecting to your pc via your home router.
then yes.....you need to plug a straight through cable into your cisco router from your home router
and it will work
if your connecting your pc directly to your router
then you need to use  a crossover cable from the back of your pc...to your cisco router.
and it will work
