Warning message
ISE HTTP GUEST PORTAL
Oct 6th, 2014
We have some disconfort with Guest web authentication. When WLC redirects a guest user, he views certificate error.
Can I use http instead https for guest portal?
Oleg
Dhiresh Yadav Mon, 10/06/2014 - 23:51
  • Silver, 250 points or more
Is your guest portal on the ISE ? In the ISE , there is only HTTPS port allowed to configure under Guest portal and no option of http port is there , So I dont think so. You also might be using port 8443 in the external web-auth redirection URL under security tab.
Now even if you put a valid certificate on the ISE which hosts external guest portal , still you would receive certificate warning as long as you use local web server of the controller which is its virtual ip address.This is because even if the external web server where page is hosted for example has a valid certificate , even then internal virtual ip address is presented to the client.
So
> either you trust them in your browser so that you dont receive certificate warnings
>or else have a valid certificate on the controller and external web server.
> or use http for web authentication in the controller and also http to external hosted page, then also you can get rid of these certificates.
Dhiresh
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
