2 3750 ip base switch intervlan routing between vlans
rfrancis11
I have 2 3750-e ipbase switches on a port channel trunk encap 1.q i want to configure 2 vlans on each one and have them talk to eachother how can i make it work
like switch 1
vlan 10
interface 192.168.1.10 255.255.255.0
vlan20
no ip
switch 2
vlan 10
no ip
vlan20
interface 192.168.2.10 255.255.255.0
computer connected to switch 2 with ip 192.168.2.200 cannot ping 192.168.1.10
Reza Sharifi
You first need to decide what switch is going to do the routing between the vlans for you.
Your config above shows that one switch has an SVI for vlan 10 and the other has an SVI for vlan 20.
If you want switch-1 to route between vlans, then you need to configure both SVIs on that switch.
Example:
switch-1
vlan 10
name test-vlan-10
exit
inter vlan 10
ip add 192.168.1.10 255.255.255.0
no sh
exit
switch-1
vlan 20
name test-vlan-20
inter vlan 20
ip add 192.168.2.10 255.255.255.0
no sh
now you need to add the trunk to the interface connecting to switch-2
example:
switch-1
interface gi0/1
switcport
switchport mode trunk
switchport trunk enc dot.q
Do the same for switch-2
interface gi0/1
switcport
You also need to make sure you have the "ip routing" command on the switch with the 2 SVI's
on switch 2 do i have to also make the vlan's?? but with no ip address? and map the ports i want to the appropriate vlan? like so:
switch-2
vlan 10
name test-vlan-10
exit
switch-2
vlan 20
name test-vlan-20
exit
int gigabitethernet1/0/1
switchport mode access
switchport access vlan 10
exit
int gigabitethernet1/0/2
switchport access vlan 20
exit
Thanks again!!
Yes if you are not using VTP client/server mode between the two switches or if you have the VTP mode set to transparent you will need to create the VLAN's like above in order to assign the switch ports to that VLAN like above.
