Warning message
Need help to understand the MEMORY output on WLC
Oct 8th, 2014
Hi All,
Will be glad if someone can help me to understand the below output from WLC. Actually i want to know the FLASH & RAM size of my WLC so what i did. I run the command '' show memory statistics'' and below is what i have got. Can someone elaborate this
System Memory Statistics:
Total System Memory............: 259112960 bytes  (i believe this is the flash size 256Mb ???)
Used System Memory.............: 154288128 bytes
Free System Memory.............: 104824832 bytes
Bytes allocated from RTOS......: 13717504 bytes
Chunks Free....................: 24 bytes
Number of mmapped regions......: 37
Total space in mmapped regions.: 23429120 bytes
Total allocated space..........: 13399760 bytes
Total non-inuse space..........: 317744 bytes
Top-most releasable space......: 61832 bytes
Total allocated (incl mmap)....: 37146624 bytes
Total used (incl mmap).........: 36828880 bytes
Total free (incl mmap).........: 317744 bytes
Rasika Nayanajith Wed, 10/08/2014 - 16:52
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
Hi Salman,
Yes, that value give the RAM size of your WLC.
259112960 bytes  valued correlated to ( or 23040 KB or ~248 MB ) dividing by 1024. So I think it is 256MB RAM.
I do not think flash size can be determine by this output.
Refer this post as it relate to your query as well
https://supportforums.cisco.com/discussion/12023396/ram-size-5508-and-5760-wireless-lan-controllers
Rasika
*** Pls rate all useful responses ****
salman abid Wed, 10/08/2014 - 21:33
Hi Manannalage,
Thanks for the reply. Now how i'll be able to see flash size?? as i have multiple types of WLC 2100series, 4400 series & 5500 series
Rasika Nayanajith Wed, 10/08/2014 - 22:21
    2017 Wireless
Hi Salman,
I do not know a command to look at this detail for AireOS WLCs ( in IOS WLC it is "show ver"). Unless Cisco publish these detail I do not think you can find it.
By the way what is the importance of finding this ?
Pls do not forget to rate our responses if that is useful
Rasika
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
