Warning message
default login for spa 303
Oct 8th, 2014
I lost the password and login of my ip phone SPA 303
So i cant do anything with it
how can i reset the login and password and or get a new one (or get rid of it altogether).
pls
help
Dan Lukes Fri, 10/31/2014 - 02:20
  • Red, 2250 points or more
  • Cisco Designated VIP,
    2017 Small Business
Do reset to factory default. Note that it can be disabled by configuration. If it is disabled on your device ask device administrator to ublock it or perform reset by self.
If you are only administrator of the device, you blocked the reset to factory default feature and you forgot the device password, you are out of luck.
