show port-channel traffic
Oct 9th, 2014
Hello all,
I have 3 port-channels configured for LACP on our Nexus1000V. The uplinks end on a 2960S stack switch, where LACP is also configured.
By running "show port-channel traffic" I get the following.
sh port-channel traffic
ChanId      Port Rx-Ucst Tx-Ucst Rx-Mcst Tx-Mcst Rx-Bcst Tx-Bcst
     1    Eth5/3  37.83%   0.00%  48.05%  50.32%  16.97%  27.52%
     1    Eth5/4  62.16%  99.99%  51.94%  49.67%  83.02%  72.47%
     2    Eth3/2  19.66%  85.56%  47.82%  58.93%  14.60%  94.64%
     2    Eth3/4  80.33%  14.43%  52.17%  41.06%  85.39%   5.35%
     4    Eth4/2   3.54%  97.92%  39.71%  51.32%  27.00%  59.91%
     4    Eth4/4  96.45%   2.07%  60.28%  48.67%  72.99%  40.08%
My question is, why isn't traffic evenly distributed between ethernet interfaces, belonging to the same port-channel.
Load balancing is configured as follows:
sh port-channel load-balance
Port Channel Load-Balancing Configuration:
System: source-mac
Port Channel Load-Balancing Addresses Used Per-Protocol:
Non-IP: source-mac
IP: source-mac
Thank you in advance,
Katerina
Overall Rating: 5 (1 ratings)
Harish Balakrishnan Thu, 10/09/2014 - 07:25
  • Silver, 250 points or more
Hello Katerina
This is pretty much expected result when you have one server send out more traffic. If you could change the load sharing method to src-dst-ip or src-dst-mac ( based on your traffic flow) you should be able to see better results
Hope this helps
Harish.
katerina.dardoufa Mon, 10/20/2014 - 06:33
Thanks for the link and the great information.
I will try to change the algorithm and see what happens.
InayathUlla Sharieff Thu, 10/09/2014 - 07:44
  • Cisco Employee,
This is expected result.
AS said if you want to see some different or close match between the interfaces you need to try changing the load balancng algorithm on the device.
