10-09-2014 07:21 AM
Cisco Forum:
How might a person obtain a copy of Cisco's Prime Collaboration Deployment software/OVA?
Downloading Cisco software lists lots of Prime Collaboration 10.5 offerings but not the Deployment option. Cisco's PUT Tool offers Prime Collaboration Standard 10.X but is failing with an internal error before I can even determine what might be contained with it.
How might Cisco's PCD software/OVA be obtained?
Thank you.
Dan
Solved! Go to Solution.
10-09-2014 07:48 AM
U would get PCD with title as PMEDIA;Cisco Prime Collaboration Deployment V10.5(1) after u had placed order through PUT.
regds,
aman
10-09-2014 07:48 AM
regds,
aman
10-09-2014 08:02 AM
for OVA
Cisco only supports virtualized deployments of Cisco Prime Collaboration Deployment. PCD is deployed using an OVA that contains the pre-installed PCD application. This OVA is obtained with a licensed copy of Cisco Unified Communications Manager Release 10.5(1) software. For information about how to extract and deploy the PCD_VAPP.OVA file,
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/rel_notes/PCD/CUCM_BK_PB8976C2_00_pcd_rns_1001/CUCM_BK_PB8976C2_00_pcd_rns_1001_chapter_01.html
for extracting OVA
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/pcdadmin/10_5_1/CUCM_BK_U35347D2_00_pcd-administration-guide-1051/CUCM_BK_U35347D2_00_ucmap-administration-guide-1051_chapter_01.html#CUCM_TK_E008CD66_00
10-09-2014 08:12 AM
[+5] to Michael.
regds,
aman
10-12-2014 10:30 AM
10-13-2014 10:10 AM
Hello Aman,
Looking at this snapshot, I guess I picked the wrong product group in PUT. I should've picked Communications Manager instead of Prime Collaboration (attached).
Funny thing happened this morning. A media kit came in the mail today and it has PCD. I still want to know if my mistake was just picking the wrong product group in PUT. This way, other can learn from my error.
Randy
10-13-2014 10:36 AM
Hi Randy,
U should have selected Communications Manager instead of Prime Collaboration.U get other options as Jabber,Presence, Voice Messaging.
After u select , Cummincations Maanger, u get Product Option[Export Restricted/Unrestricted] followed by Current version and Upgrade Version.
regds,
aman
10-13-2014 11:41 AM
Thanks for clarifying Aman. Truly appreciate your help and the time you spend assisting users like me here in Cisco support forum.
Best regards,
Randy
10-09-2014 08:04 AM
PCD comes with CM10 media kit and you order that via the PUT tool.
10-10-2014 03:59 PM
Hello Michael,
I don't have a CM10 Media kit. I've got ISOs and OVAs in my BE6K and PCD is nowhere to be found in there. I've tried going through the PUT but did not find PCD there as well. I ordered Prime Collaboration Standard thinking it's within that product but I was mistaken. Can you tell me how exactly to order this through PUT? I just need to get my hands on this "free" product that is extremely difficult to find. I need to migrate CUCM, UCCX and with what I've read so far, PCD would be a great help.
Randy
10-10-2014 10:20 PM
Hi Randy,
can u share what all u have got in BE6K ?
regds,
aman
10-13-2014 09:49 AM
10-12-2014 06:59 AM
There is nothing labeled in the PUT tool as PCD. You must download PMEDIA;Cisco Prime Collaboration Deployment V10.5(1) as stated in Aman's post.
