10-09-2014 09:15 AM - edited 03-17-2019 12:29 AM
Support Forum,
I have been writing test SQL queries against the 'licensingresourceusage' and 'licenseserver' from the UCM Data Dictionary 10.0 and have not come across a method to retrieve total licenses, either 'Required', 'Installed' or 'Available' in ELM/PLM.
I have retrieved licenses allocated to an enduser e.g. tin, copper, bronze, etc. But I cannot find the overall license summary.
Does the ELM/PLM run a separate dB with no SQL access? or I am not using the correct command syntax for the given tables in the UCM 10.0 Data Dictionary.
Any suggestions would be greatly appreciated. Thanks.
Solved! Go to Solution.
10-09-2014 10:20 AM
check this link for license calculation using SQL queries
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/117600-technote-cucm-00.html
regds,
aman
10-09-2014 10:20 AM
regds,
aman
10-09-2014 10:50 AM
aman,
this is a great article. Many of the SQL queries I have done are included with this doc. I was definitely on the right track. I have no digested all of the doc...but from initial scan it seems right on track. I appreciate the assistance.
David
