Warning message
Can not call transfer with VG memory issue.
Oct 9th, 2014
I can not call transfer. The issue seldom occured it.
Occurs once a month.
Then rises as high as 70% of VG memory.
And you can not use the Call Transfer.
It is resolved automatically memory falls after a few minutes.
What should I check?
Suresh Hudda Thu, 10/09/2014 - 20:53
  • Gold, 750 points or more
  • Cisco Designated VIP,
    2017 IP Telephony
Have you turn off all debug...just do 'u all' and then monitor.
And pls share o/p of below command when issue occurs.
show processor cpu history
Suresh
Eungbok Lee Thu, 10/09/2014 - 21:23
Dear,
Sorry the no memory issue and this is the CPU issue.
GW-1#sh proc cpu history
GW-1   05:04:10 PM Friday Sep 19 2014 KST
    333332222222222333332222222222333333333322222222223333333333
100
 90
 80
 70
 60
 50
 40
 30
 20
   0....5....1....1....2....2....3....3....4....4....5....5....6
             0    5    0    5    0    5    0    5    0    5    0
               CPU% per second (last 60 seconds)
       4    4    4    4    4    5    4    4    41   47   4    4
    332532337333343333633336334304433734469333354232828837322813
100
 90
 80
 70                                                  *
 60                                                  *
 50    *    *         *    *    *    *    *    *    **   *
 40    *    *    *    *    *    *    *    *    *    **   *    *
 30    *    *    *    *    *    *    *    *    *    **   *    *
 20    *    *    *    *    *    *    *    *    *    **   *    *
 10    #    #    #    #    #    #    #   *#    #*   ##** #   *#
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
    555455544444444443333333454344543444444444444445444444443333443444444455
    101921296664531529715216003812148035655667765670332840555625136203225600
100
 90
 80
 70
 60
 50 *********** *  *         *    *    *************   *  **            ****
 40 ******************* *  *********************************** *************
 30 ************************************************************************
 20 ************************************************************************
 10 ************************************************************************
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
             0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
GW-1#
GW-1#sh proc cpu | ex 0.00
CPU utilization for five seconds: 3%/1%; one minute: 3%; five minutes: 3%
 PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
  42     9275804     2323780       3991  0.63%  0.61%  0.61%   0 Per-Second Jobs
 114     2553656    43857063         58  0.15%  0.06%  0.08%   0 IP Input
 179         464   576368707          0  0.23%  0.21%  0.22%   0 HQF Shaper Backg
 202      158136      583869        270  0.07%  0.04%  0.01%   0 AFW_application_
 304      105584     1122127         94  0.07%  0.04%  0.02%   0 VOIP_RTCP
 306      161932     1591957        101  0.07%  0.05%  0.05%   0 DSMP
 315      321928     1379548        233  0.07%  0.08%  0.06%   0 CCH323_CT
 328         328   193042330          0  0.07%  0.10%  0.08%   0 CH_GT96K Backgro
GW-1#sh version
Cisco IOS Software, 3800 Software (C3845-ADVENTERPRISEK9-M), Version 12.4(24)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 25-Feb-09 23:13 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T10, RELEASE SOFTWARE (fc1)
GW-1 uptime is 3 weeks, 5 days, 19 hours, 52 minutes
System restarted at 21:11:08 KST Sat Aug 23 2014
System image file is "flash:c3845-adventerprisek9-mz.124-24.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 3845 (revision 1.0) with 221184K/40960K bytes of memory.
Processor board ID
2 Gigabit Ethernet interfaces
124 Serial interfaces
4 Channelized/Clear E1/PRI ports
1 Virtual Private Network (VPN) Module
12 Voice FXO interfaces
2 Voice E & M interfaces
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
aseanand89 Thu, 10/09/2014 - 21:13
Along with the output requested by Suresh, send us the following:
1. Show version
2. Show flash
3. show memory dead
Also, if possible can you send us the output of Show process memory when the issue occurs
