several VPN Connecions
Oct 10th, 2014
I need to have several VPN connections available.
Cisco AnyConnect writes (one) profile in the preferences.xml located in C:\users\...\Appdata\local\cisco\Cisco AnyConnect Secure Mobility Client\
Hos can I add more profiles here ?
Syntax, Naming convention, etc ... ?
<?xml version="1.0" encoding="UTF-8"?>
<AnyConnectPreferences>
<DefaultUser>User1
</AnyConnectPreferences>
<DefaultUser>User2
Marvin Rhoads Fri, 10/10/2014 - 21:22
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
Connection profiles should generally download automatically from the ASA you connect to. If you really need to create them for manual deployment, you can download the AnyConnect Standalone Profile Editor (via download software link on AnyConnect product support page) for offline creation and storage.
The syntax is explained in lots of detail on the administrator guide (see the link under Configuration Guides).
By the way the AppData folder location is for global AnyConnect preferences. Individual VPN profiles are found at C:\ProgramData\Cisco\Cisco AnyConnect Secure Mobility Client\Profile on Windows 7 and 8. File locations for other operating systems are documented in the administrator guide.
