Prime Provisioning UCXN Infrastructure sync error
Oct 12th, 2014
Hi all,
When trying to do an Infrastructure sync for unity connection 10.5, I'm getting the following error.
Failed to sync infrastructure data.IPT-0600: Software - Failed to create PortGroup object instance: Inventory Exception:DFC Exception IM-0022 [ERROR]: More than one object with model path -- Global Resources --:PortGroup.ID='981-70c9f38b-13c2-4e4d-bb07-59513d66962c' was found | Cause - Inventory Exception:DFC Exception IM-0022 [ERROR]: More than one object with model path -- Global Resources --:PortGroup.ID='981-70c9f38b-13c2-4e4d-bb07-59513d66962c' was found
syncInfrastructure:errorCode=600
UCXN is in a HA setup and working as expected. any thoughts?
ALEKSANDR BELAKOV Mon, 11/10/2014 - 11:01
Hi , I had the same issue few days ago when I did the set-up CUC with CUCM using Turnk, I did the following :
CUC Administration
Telephony Integrations
Port Group
SIP Transport Protocol **UDP**
IvanRomanov_2 Wed, 11/12/2014 - 03:18
I had the same error. The problem appears when you try to configure the port group with two different servers (PUB and SUB) CUCM or TFTP. The workaround I found is to create two different port groups. One group for PUB and one SUB.
