Warning message
excluding the license files during the ACE restore
Answered Question
Oct 12th, 2014
We will be recovering the ACE, running A5(2.1), during the upcoming DR test and, since the recovered ACE will already have the license file, I was wondering if we could use the exclude option when restoring the ACE, as in the following:
Restore all disk0:archive_filename exclude (licenses | ssl-files)
This would allow us to restore all the contents in a one felt swoop.
I looked up the above command in the Admin Guide, however never tried it as we don't have the ACE test bed.
Thanks.
_Greg
Correct Answer by Fnu Kanwaljeet Singh about 2 years 10 months ago
Hi Greg,
This should work fine. But honestly, i haven't tried this myself either. It is mentioned in  the documentation and things are tested before they make it there. Checked other cases too. Just keep note of the below:
"If you upgrade to software version A4(1.0) or later from a release before A4(1.0), the ACE cannot install the earlier license files because they are unsupported. The ACE ignores these license files and keeps the existing licenses".
Kanwal
Note: Please mark answers if they are helpful.
Overall Rating: 5 (1 ratings)
Correct Answer
Fnu Kanwaljeet Singh Sun, 10/12/2014 - 20:07
  • Cisco Employee,
Hi Greg,
Kanwal
axfalk Mon, 10/13/2014 - 12:05
thanks for your reply - very helpful as always...
