Warning message
CER High Utilization
Oct 13th, 2014
I am new to supporting CER via Cisco Operations Manager.   I am asking for guidance on supporting the following intermittent Error Messages reported in Operations Manager:
1.  Critical 000DGDQ cer1.xyz.com cer1.xyz.com/0 HighUtilization 08-Oct-2014 14:54:21 Cleared
2.  Critical 000DGDP cer1.xyz.com cer1.xyz.com/0 HighUtilization 08-Oct-2014 14:44:21 Active
Errors appear and then clear. I cannot find reference to the 000DGDP/etc.In Linux, VMware or Cisco Applications.
The CER version is 8.5.1.10000-7
VMware (Version 4.0.0 Build 208167)
As always thanks for any help.
Manish Gogna Tue, 10/14/2014 - 02:53
  • Cisco Employee,
Can you try a restart of the SNMP Master Agent service and see if the issues goes away. if not, then this needs to be investigated further by collecting logs for the relevant time stamp.
Manish
tknapp Tue, 10/14/2014 - 04:51
Thank you for the fast response.  I will have access to equipment  tomorrow 10/15.  I will follow your suggestions and let you know what I find.
