split switch for dmz
n14nguyen
I got a layer3 switch cat2960xr that connected behind the firewall for inside network.  Is it possible if I can use part of the switch (few ports) for the dmz zone or I have to purchase separate switch for that?  Please see attachment.
I noticed your SVI for vlan 2 is incorrect IP address: "192.168.1.0 255.255.255.0" so change it to something different IP address from what you have assinged to ASA's inside interface such as: "192.168.1.2 255.255.255.0".  I hope you have something like this on your ASA's inside interface "192.168.1.1 255.255.255.0"
interface vlan2
ip address 192.168.1.2 255.255.255.0
Don't forget to add a default route, pointing to your ASA's inside interface address, on the switch as shown below.
ip route 0.0.0.0 0.0.0.0 192.168.0.1
Last but not least, you don't forget to create dynamic nat for your hosts on your ASA located inside your network.
thanks
8 Replies 8
rizwanr74
Level 7
Level 7
Hi n14nguyen,
Yes you can, as long as your 2960-switch hosts only later2 vlan for your dmz, and your DMZ interface on ASA is being gateway for DMZ hosts.
thanks
Rizwan Rafeek
So you mean create a vlan for dmz.  How am I ensure the separate between of inside vlan and dmz vlan in the same switch?
Hi n14nguyen,
Lets assume that your dmz interface on your ASA is "192.168.11.1 255.255.255.0" and is connected to FastEthernet24 on your 2960-switch and similarly your inside address of your ASA is "10.10.10.1 255.255.255.0" and is connected to FastEthernet1 on your 2960-switch.
Now on your 2960-switch you create a SVI interface for your inside network of your ASA and layer2 definition as vlan 10 and for DMZ you only create a layer2 definition only as vlan 11.
interface vlan10
10.10.10.2 255.255.255.0
no shut
vlan 10
 name asa-inside
vlan 11
 name asa-dmz
interface FastEthernet1
 switchport access vlan 10
 switchport mode access
interface FastEthernet24
 switchport access vlan 11
Note that I do not have a SVI created for vlan 11.
I hope this make sense.
Rizwan Rafeek.
thanks guys,  I will try
interface vlan2
thanks
yes, correct IP adddress and addded ip route for inside network address resolve the problem.  Thanks
I've tried yesterday,  only machine on dmz1 port (interface GigabitEthernet 1/0/24) can access to the internet but the inside port (interface GigabitEthernet 1/0/2) can't .  Am i missing anything?  I attach the current running-configure
If you had the following it would work:
Switch:
VLAN 1 - inside
VLAN 2 - dmz
switchport 1 (inside) - access mode vlan 1
switchport 2 (dmz) - access mode vlan 2
Firewall:
port 1 (inside) - (ip address + plugged into switchport 1)
port 2 (dmz) - (ip address + plugged into switchport 2)
Then configure any switchport as vlan 2 if you want the attached device to be on the dmz network or vlan 1 if you want them to be on the inside network.  You could use the firewall for DHCP for that vlan 2 dmz subnet and set the default gateway to the IP address of the firewall's port 2.
This will create LAN separation between the two networks.  You will literally have two networks using the same switch...a.k.a. Virtual Local Area Network (VLANs).
Like Rizwan mentioned, this works in a layer 2 switch.
