Warning message
QoS
Oct 14th, 2014
Hi Please help me on this:
How to configure QoS for Video Conferencing . which parameters I  should  follow for this.
Installed VC Device like this VC Device àCore Switch [Native VLAN]àFirewall [5505 ASA]àCisco Router[2900]àISP
NAT=192.168.X.X to 125.X.X.X in Firwall
Should I configure QoS into all Network Device [Switch+Firewall+Router]
I have configure QoS like this as below:
lass-map match-all VC_Traffic
 match dscp ef
 match dscp af31
 match dscp af41
policy-map Outbond_Policy
 class VC_Traffic
  priority percent 20
ravinder.bora Thu, 10/16/2014 - 11:43
Hi Amit,
QoS configured on Router and apply on WAN interface. But still Video Stuck.
also check in MRTG Graph no over utilization of Link.
Ravinder
Joseph W. Doherty Tue, 10/21/2014 - 05:13
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
A FW and NAT, eh?  Are you running across the Internet?  If so, is link also used for "generic" Internet access?  If first, often shaping is needed if two sides have different bandwidth connections to the Internet.  If also the second, unless you can enable QoS on ISP egress toward you, you cannot effectively manage ingress.
ravinder.bora Tue, 10/21/2014 - 10:18
I joseph when I bypassed firewall then VC is working fine no packet drop. But when Firewall is working in between VC and router then packet drop.
That’s mean Firewall[ASA 5505] Drop VC packet.
125.19.X.X is VC ip which is NAT with private IP
access-list outside_acl extended permit icmp any host 125.19.X.X
access-list outside_acl extended permit tcp any host 125.19.X.X eq ftp
access-list outside_acl extended permit ip any host 125.19.X.X
access-list outside_acl extended permit tcp any host 125.19.X.X eq h323
access-list outside_acl extended permit tcp any host 125.19.X.X range 2326 2373
access-list outside_acl extended permit udp any host 125.19.X.X eq 5555
access-list outside_acl extended permit udp any host 125.19.X.X eq 1719
access-list outside_acl extended permit udp any host 125.19.X.X range 5555 5587
access-list outside_acl extended permit udp any host 125.19.X.X range 2326 2373
access-list outside_acl extended permit tcp any host 125.19.X.X range 5555 5587
access-list outside_acl extended permit tcp any host 125.19.X.X range 963 965
access-list outside_acl extended permit udp any host 125.19.X.X range 970 974
