10-14-2014 05:40 AM - edited 03-04-2019 11:58 PM
In my router, there is a default route with the administrative distance 1 with track 1 This route is used for an internet link.
0.0.0.0 0.0.0.0 172.19.4.10
I also have 2 dialers to redundancy with the administrative distance 20 and 30 respectively.
ip route 0.0.0.0 0.0.0.0 dialer1 20
ip route 0.0.0.0 0.0.0.0 Dialer2 30
When I set up a route with track and give a shutdown on subinterface, the route takes the dialer.
But when I give a no shutdown on the port, which is the route with the track becomes more specific, but the same does not appear in the routing table.
I'm using two routes, one with and one without track the track to the same destination:
RTR(config)#do sh run | i ip route
ip route 0.0.0.0 0.0.0.0 172.19.4.10 track 1
ip route 0.0.0.0 0.0.0.0 Dialer1 20
RTR(config)#interface gi0/0.303
RTR(config-subif)#shut
RTR(config-subif)#do ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 0 percent (0/5)
RTR(config-subif)#do sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, + - replicated route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
S* 0.0.0.0/0 is directly connected, Dialer1
RTR(config-subif)#no shut
RTR(config-subif)#ip route 0.0.0.0 0.0.0.0 172.19.4.10
RTR(config)#do ping 8.8.8.8
Success rate is 100 percent (5/5), round-trip min/avg/max = 84/87/88 ms
Anyone know what I have to do to solve the problem?
Solved! Go to Solution.
10-14-2014 08:41 PM
With the default route up (172.19.4.10), test connectivity to "Dialer1" and "Dialer2". These need to be reachable for obvious reasons, once we lose our tracked route and Dialer1 is placed into the routing table, it's no use if we don't have connectivity to backup route/s.
I would also recommend using higher metrics for "floating" statics. I'd personally do
ip route 0.0.0.0 0.0.0.0 Dialer1 249
ip route 0.0.0.0 0.0.0.0 Dialer2 250
Better practice for when you have dynamic routing protocols in place etc. Again, your floating static is doing it's job so that's not an issue, it's more of an issue as to why your device cannot reach Dialer1 or Dialer2
10-14-2014 06:10 AM
Please can you display configuration concern IP SLA ??
10-14-2014 06:21 AM
I'm testing the gateway Internet link of the carrier.
Below is the configuration of IP SLA:
ip sla 303
icmp-echo 189.40.251.174
ip sla schedule 303 life forever start-time now
track 1 ip sla 303
10-14-2014 08:41 PM
10-17-2014 04:49 AM
My dialers are not good, but would fix them at another time. My goal now is to monitor my primary internet link.
I removed the two routes of Dialers, but the problem persists:
RTR#show run | i ip route
RTR#conf t
Enter configuration commands, one per line. End with CNTL/Z.
RTR(config)#no ip route 0.0.0.0 0.0.0.0 172.19.4.10
RTR(config)#ip route 0.0.0.0 0.0.0.0 172.19.4.10
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/11/16 ms
